Yzracer239
- Joined
- Aug 16, 2015
- Messages
- 51
Ive got a 610 which I bought last year and though it was only a very short moment when limping it off the trailer, I know it ran, and seemed pretty well too. Fixed a bunch of mechanical stuff needed, now back to getting it running so I can use it. Im having trouble getting it to start and stay running...but mostly start. Other than a few seconds, some with ether, some without, I cant seem to get it to fire and stay running. I have the air cleaner assembly off, so open carb. When I crank it for a few seconds then stop. Raw fuel dumps out the intake side of the carb. Behind the mechanical fuel pump on the block, there is a petcock looking lever device. What is that? right now the little lever on it is in the vertical position. I have 4 new sparkplugs, checked for spark on all cylinders, and checked compression. It has 90, 100, 110, and 110 psi. I had the carb off last week, took completely apart, polished all brass, bead blasted the body, and returned all screws to same position(assuming they were right, though I know it ran), and made new cork gaskets. I was a slightly unsure making the gasket for the two carb halves, as the one on it was also home made, but poorly made. There was a certain portion I was unsure to leave gasket material in place or not, though I cut it out, as it seemed to make more sense. Seemed to be some kind of passage, though I dont see that being my issue. Maybe it is and I should order and oem gasket. Any help why my carb is dumping fuel and what is the lever behind the petcock.
