I got an update on my 453. I fianlly got it all put back together...new rings, new valves, ridge ream and flex honed the cylinders, and the head rebuilt and vacuum tested and adjusted the rocker arm tolerance to spec. Put it all together today and cranked it over for its maiden voyage. However, it took several cranks to get it started and then would run for maybe 5 seconds then die. I did get it to start once and had it idle fine for about 8 mins but then when i went to increase the throttle(it was at like half) then it sputtered and died. I believe it is a fuel problem now because when i squeeze the bulb and check the lines i get good fuel pressure all the way up to the transfer pump. I just replaced this transfer pump before i tore out the engine so i think it is good?? Kinda nice because so far i am into it for just under 1k. But what do you guys think about the fuel pressure problem. When i have the bleeder valve open i should be able to squeeze the bulb really easily right?? Thanks for all the help you guys have given me, it is VERY APPRECIATED!!
