Only problem is I believe the lower are blind holes so hopefully your blade can get in there to cutrainy day so I decided to replace that center tilt pin on the bobtach. Pin came right out no problemo. I heated and cooled the bushing and had a socket the right size so I pounded on it for about an hour or so. It moved a 16th of an inch maybe and I busted up the socket. Went to Lowes and picked up a Diablo Brand Carbide Thick Metal cutting recip blade for my sawzall. In about 5 minutes overall, I was able to cut 2 slots in the bushing and the piece popped out. Then the bushing popped out so fast I didn't see it on the ground. I only deeded to cut one slot as it would have been enough to free up the bushing. This blade is awesome. Never even affected the teeth. Had the new bushing in the freezer and it drove right in. Couldn't get the two small seals on however as they got tore up when I tried to get them in. No play in this pin and bushing now. NONE! Hoping the pins and bushings on the two lower arms will be as easy when I am ready. Thank you everyone for the support and great ideas.
