My 863F is starting to leak quite a bit of fluid out the front opening in the belly pan, what's the most common hydraulic leak (s) that I should look for? thanks for any help! Gary
It could be anywhere really. Lift the cab and give it all a good clean, this will help you find any oil leaks. When its clean, its much easier to find a leak.
I also have an 863 Turbo model F. I get some leakage from the back of the belly pan where the small access plate is. Not all the time. I am told there is a drain plug under that access plate is suggusted to be replaced when you drain the oil. I plan on getting in there to see if any of the plugs are lose or leaking. Is the plug under the access plate a sacrificial plug? Anyone know?
