773 no steer left side
anybody know what's the problems Where to start looking to resolve the problem Please help thanks
Depends, does the engine bog down when you try and move? is it locked up or does it free wheel?
the engine run perfect I can steer to the right or go in circle but not to left Is not power all all to the left wheels
First check out the linkage making sure everything is fine there. Next put the unit on blocks. Remove and cap the drive motor hoses on the bad side. Start the unit and run the drive. If the engine pulls down under load, the pump is good. I think your is the current vintage for o ring failures causing loss of power. Reseal motor be on your way.
