Sep 16, 2015 #2 O oog New member Joined Sep 16, 2015 Messages 3 is there anyway of replacing the manifold without pulling the engine big leak at the right side it's a high flow if that make a difference thx Mark
Sep 16, 2015 #3 B Bobcatdan Well-known member Joined May 3, 2012 Messages 1,684 No need to pull the engine to replace the manifold. Pull the muffler and go to it. If you need for more room because of broken studs. With the arms up and the cab flipped, pull the cooling fan housing out. Manifold is most likely cracked.
