After 2 hours plus of digging online, I have decided I do not have the right term for the component I need info on... Our 763 bucket positioning valve fittings rotted out on one side (the side buried under the frame, facing the bucket), and we just got the parts to replace the failed piece, and the rest on that side. The assembly we need just a bit of help with is a screw that holds a pin in the block, and has a plastic cap. Not the spool (no springs nor balls), just an adjustment screw. The dealer mentioned it is the float level setting, but when can I find a reference to set a starting point, in under three days?
I feel as though it is a simple "trick" one usually finds out about two weeks after doing it the hard way.... All suggestions welcome
