763 Blower Fan Rattling?
BobCat
I'm not real sure but I think my cooling fan is making some noise? At different RPMs the sound changes. Is that a common problem with that type of set up? Later BobCat.
What I would do is first check the oil in the blower housing as it don't hold much and cost a lot , then I would push the spring loaded , idler of the bower fan belt forward and remove the belt , then spin the fan by spinning the pulley and you should be able to see any bearing problem -----------------it may be the bearing in the idler pulley which is making the noise
