753G ACS light stays on
johnnyt
My ACS light stays on and I get a 32-65 code everytime I check for error code. I can drive but the lift & tilt valve light stays off and will not work. I can not find this code in my maintenance manual, any help would be appreciated.Thanks
32-65 is "acs sensor supply voltage out-of-range". On this code, the first place I would check is for a broken pins on the controller.
That's an odd code. Not enough info for more than this. Controller or controllers, type of system, depends on s/n.
Good Luck.
