Hi 1994 753 The hydraulic hose for the lift cylinder is leaking on the left side of the machine(as seated in it) Do I need to drain the hydraulic oil? If I remove the lines tonight....I wont have new lines to install until tomorrow night.....with it leak everywhere? Also, the hose on the inside to the rear of the cylinder is leaking. The other hose will have to come off just so I can access the nut on the leaking hose. I should probably change both. Are the other ends in the engine compartment? Any tips to R&R? Does the air cleaner need to be removed? Thanks
