751 C series where is fuse box?
ireland
Does any one know where fuse box is in a 751 c series 1996? Bobcat wont start ignition lights wont turn on. i check battery and connection every things fine only faint click when turn key any ideas?
Inside rear door, just under the top door hinge. Should be a placard on the door that indicates which fuse is which. Let us know if a fuse is the problem. :) ---RC
Ill try the fuses and let you know. Thanks
They look like relays, they have little plastic covers that fit over the 'boxes'.
Check the connections too, they are prone to corrosion. If any are bad, you can install an inline fuse in its place. Cheaper than a new harness.
I checked the fuses and they looked fine i replaced them all anyways and i also found a lose connection to the starter. And it started up fine Thanks very much for your help
