743 - Engine seems seized
Used my Bobcat two days ago, everything was fine and completed work. Parked it in workshop, came out yesterday to use it, and there is a large "clank" noise when I turn to start position and engine does not turn over.
I am perplexed, but will pull starter to see if any thing up with it, but a couple of questions:
1. I looked at starter and saw three mount bolts on front left side and a mouthing bracket on back. I cannot see right side at all and wonder if there is a bolt on that side.
2. Can the engine be turned over by hand if engine protector shield is removed? (Like a normal engine using a breaker bar/large socket?
Thanks Ron
brdgbldr
There is just the bracket and the 3 bolts in the front to remove the starter.
I would think that you could turn the engine over but I am new to diesel engines. I do know however that diesel engines run on high compression and technically you could hand crank start it as long as it is getting fuel and air.
Here is a link that you can go to and enter the serial number of your machine and it will show you exploded views that really help when disassembling and reassembling parts:
rscott7706
Thank you!
I took the engine protection plate off and was able to spin the engine, so am relived it is not seized up. It almost ahs to be the starter motor causing the issue.
Ron Scott
rscott7706
It is with apologies that I did not thank you for your reply. So, THANK YOU!!
Ron
