751 pug engine parts
I am doing a kubota swap in my 751. The pug has a cylinder that has 150 psi compression and the rest have 450. Anyone looking for pug engine parts? I just put new glow plugs in and had the injectors rebuilt by injection technologies. New water pump and pulleys. New timing belt and a spare one.
Where are you located?
Do keep in mind, the pug does run backwards, so you need to mess with your pumps to make this work
I am in Iowa. I know the pug runs backwards. I know I need to change flywheel and flywheel housing. I have to change my hydrostatic pump so it runs opposite than it is now. The fabing mounts are a simple thing. Are there any other major things I need to do? Thank you for your help?
Can you sell me the injection lines and pump for the 751? Call me 256 431 4641
It would save bobcat from death
It would save my bobcat from the dead even just the injector lines would be great truthfully call any time don't matter how late or early if you still have it
Do you know if I need to get a different puppy for the hydrostatic pump? The pully I have off a 753 is bigger than the one off the751 pug motor. I think it will make my pump run faster?
