642 engine Coolant Tmp sender (Gauge)
bfingar
I damaged the engine coolant sensor the other day that is located in the thermostat housing.......is there a standard replacement for these? It has an ID code stamped on it that looks like 1829. Not sure what the range is. It looks like a 1/8" npt connection with single threaded terminal. I tried to cross reference the id # but have not come up with anything.
Get it from the dealer, it's matched to the gauge, they are pretty cheap.
SkidRoe
The Bobcat part number is 6658818, and is common across multiple models.
You will likely have to go to Bobcat for it.
Cheer - SR
B
bfingar
Cheer - SR
Thanks guys! $25 at local dealer. Should be in a week. Cheaper than I thought. No rush, I have the motor out of it to find a leak which appears to be in a line that runs under the motor and pumps.
