- Joined
- May 11, 2011
- Messages
- 100
Searching through 335P owner's manual, didn't find anything on how to enable Joystick press-buttons and proportional-rollers. Nor anything on how to label what a press-button does or a proportional-roller does.
The attachment manager has various John Deere attachments (bucket, trencher, snow-blower, backhoe, ...) and option for non John Deere attachment in same category. Depending on attachment, press-button may do something or be flagged as unavailable, same with proportional rollers (of left & right joysticks).
You can add your own attachments, set name for attachment, and depending on base attachment you start from you can modify hydraulic flow (forward/extend) and sometimes flow (reverse/retract), and normal/high pressure. You can look at Joystick press-button and proportional rollers; but I can't find a way to enable or edit names.
Reason I am asking is I have new box blade which has Left side of blades up/down via hydraulic cylinder and Right side of blades up/down via another hydraulic cylinder. But I can't find a built-in type under attachment manager which utilizes Proportional roller of Left Joystick and Proportional roller of Right Joystick.
I would have thought there was some "Blank" type attachment which by default had all press-buttons and proportional rollers enabled. Whereby you would duplicate "Blank" type, giving it a new name and ICON. Followed by editing names of press-buttons and Proportional rollers.
Is there a "Blank" type attachment as described above, I missed?
Does anyone know how you enable press-buttons and proportional rollers for existing attachment?
What about editing press-buttons and proportional rollers from whatever they are called to desired name. For example "Swing Left" or "Function 3" to Left-Up?
