310 Steering Clutch
kpmunt
I purchased a 310 that has a very "stiff" steering handle. I've taken the cover off the gear box to look at the chains and gears. In trying to adjust the clutches per the book I find that the bolt/shaft turns all the way through rather than just the nut. So the question is, what is the appropriate way to make this adjustment? Adjusting from either side seems as if it will impact both clutches since the shaft is turning.
