240 hydraulic pump
Blaine
Anyone know where I could get a cheap used hydraulic pump. The ears the bolt the pump to the bellhousing broke off. Thanks! Blaine 770616-6379
If you can find out what brand the pump is, you may be able to buy after market parts for it, especially if it is a vickers pump. I have seen quite a few after market parts for vickers pumps. Failing that, you may need to sell a kidney or 2 and get it off your skid steer dealer.
goodtech
I would honestly take it down to your nearest Hydraulic repair shop and have them at least order you the part of the case that you need, and a seal and oring kit for it. All these dealerships charge way to much, for a simple pump assemble. Good luck on your search
B
Blaine
The pump has a sticker on the side with barcodes and numbers etc. It also says Easton on it. I will definetely try some of the local hydraulic repair shops.
