Hydraulic oil
Gordn
I have a 1997 JD 7775 skid steer and can't find were to check the hydraulic oil level. I bought it with the gauge cluster not working, are they repairable or are there any new ones.
Gord
just a guess here, but I would think you can check the fluid level on the fluid tank itself, most have a mark on them to show full,
as for gauge cluster, odds are its a discontinued part, but you may still be able to find a good used one, from salvage yards, Ebay, or else where on the world wide web
Might even find someone that sells retro fit gauges too, if you do some digging online!
if you have a GOOD dealer near you, you can also try asking them about gauges, they might know where to find one either used or possibly even new
but odds are they won't be cheap, no mater where you find one/if you find one for sale!
Does anyone know where the glow plugs for a 320d skid steer or is there a way to keep to plugs on longer
The glow plugs are usually located in the cylinder head near the intake manifold—should be easy to spot if you follow the wiring harness. As for keeping them on longer, it might depend on the control module settings. It could be worth checking the manual or consulting a dealer to see if adjustments can be made.
