2014 Case SR210 Eats Starters
Bryan60
Case SR210 Eats Starters-
I have a 2014 SR210 that eats starters. I have owned it about 2 years and this will be my 4th starter. I asked the dealer where I buy my parts about the issue and the last time they told me to check all the connections to the starter so I put Di-electric grease on all the connections this starter lasted 2 1/2 months. They have always warrantied the replacements but this time they are saying they may not. Does anyone have any suggestions on a solution?
foton
I assume that it is a electrical issue that you have a issue with . I think the most over looked things are grounds, you can always add a cable from the batterys negative side to one of the mounting bolts to the starter. Then try starting and see if your cranking speed increases, if it does that was your problem.
