rusfarmiowa
- Joined
- Jan 25, 2025
- Messages
- 7
The machine was working just fine when I loaded onto the trailer but when I got home, I started it. It ran for about three minutes and then it flashed the code 1051. I found a loose connection on the disconnect. It appeared to be a grounding wire that Went to the left side of the disconnect. I repaired that wire and charge battery, cleaned all of the ground connections, checked the fuses, and still showing same fault code and today an additional code 9153 showed as well.
