2013 TR270 fault 1051
rusfarmiowa
The machine was working just fine when I loaded onto the trailer but when I got home, I started it. It ran for about three minutes and then it flashed the code 1051. I found a loose connection on the disconnect. It appeared to be a grounding wire that Went to the left side of the disconnect. I repaired that wire and charge battery, cleaned all of the ground connections, checked the fuses, and still showing same fault code and today an additional code 9153 showed as well.
10 to 1 you have a couple relays down below where you have to pull the battery out to see them. I believe the top one gets ground from the ECU which is the one that gets power to fuses for the start system.. A genius at Case figured if you buried it, it would never fail. Non the less start by checking the fuses
