Bobcat claims that their fluid is custom blended for them.
Here's what they say on their website.
"Bobcat recommends you use Bobcat® Hydraulic/Hydrostatic Fluid because it is a unique fluid, custom blended with the finest base oils and additives to meet Bobcat Engineering's stringent specifications for quality and reliability. It is the same premium fluid as factory fill.
Bobcat Hydraulic/Hydrostatic fluid is a special blend of high quality lubricants designed to provide optimum flow at subzero temperatures yet maintain excellent stability during periods of high temperature use.
Bobcat's Hydraulic/Hydrostatic fluid formula cannot be duplicated from off-the-shelf hydraulic fluids.
This exclusive hydraulic/hydrostatic fluid is now blended with a distinct orange color to distinguish it's uniqueness from other fluids. "
If your machine is still under any warranty then you should buy the fluid from them as anything else will void it.
Otherwise you can use one of the super tractor oil universals(STOU) that say they meet the specifications for hydrostatic transmissions.
If you look at page 20 here
http://www.sauer-danfoss.com/stellent/groups/publications/documents/product_literature/520l0463.pdf
You'll see what Sauer-Danfoss says you can use with their hydrostatic components including some engine oils.
