2008 Case No Crank
GaryV.
2008 Case 435 series 3, diesel engine. Having a no crank problem, used skidsteer as normal, parked it and 1hour later it would not engage the starter. Starter looked old so threw one in and same thing. Can hear the seat warning and light when you sit in the seat as normal. glow plugs come on. Turn the key and hear a relay in the fuse panel "click" but no crank. checked battery, cleaned terminals at battery.
Seems like it is not getting power to the white wire on the solenoid at starter, hard to test as the cab has to be tilted forward to get to starter. Ordered a manual ($121) to get wiring diagram. Seems to not have a starter solenoid other than the one on starter, like the glow plugs do. HELP.....scratching head.???
bypassed the system with a push button from Oreilly's.... will look into it more when the manual arrives...thanks
