D DLS1369 New member Joined Dec 18, 2018 Messages 1 Dec 18, 2018 #2 First time mustang owner want to lift cab. Does it tilt ?
F farmshop Well-known member Joined Mar 27, 2014 Messages 698 Dec 19, 2018 #3 Nope they are bolted on the 4 corners. You can acces most of the stuff by lifting the seat or removing the belly pan
M mshull New member Joined Feb 21, 2024 Messages 4 Feb 21, 2024 #3 farmshop said: Nope they are bolted on the 4 corners. You can acces most of the stuff by lifting the seat or removing the belly pan Click to expand... Can't get to the hydraulic coupling from belly pan or the seat access. Any suggestions?
F Firefighter Well-known member Joined Dec 31, 1969 Messages 266 Feb 22, 2024 #4 the engine / pump coupler, needs to be replaced by removing the engine, if u dont have access to a lift, u can unbolt the engine cradle from the frame (1/2'' Bolts), n slide the engine back a foot or so then u can remove the coupler
