2005 2044 cab
farmshop
Nope they are bolted on the 4 corners. You can acces most of the stuff by lifting the seat or removing the belly pan
Firefighter
the engine / pump coupler, needs to be replaced by removing the engine, if u dont have access to a lift, u can unbolt the engine cradle from the frame (1/2'' Bolts), n slide the engine back a foot or so then u can remove the coupler
