2000 4835sxt attachments unhook from quick attach
Candyman
Hello all.New to the forum.I am having trouble with my bucket and back hoe attachment staying hooked.If I back drag with the bucket or apply a good bit of force using the back oh the pins become unhooked and they come off.Any thoughts?Thanks.
Are the attachment holes on the bucket worn? THe pins should hold the bucket/attachment on tight, even with back dragging.
C
Candyman
I thought that was the problem because the previous owner make a ohm made quick attach plate and the bottom doesn't meet nice.there is a gap about 1/2 inch.but the back hoe isn't worn at all.Do the pins wear fast or is there an adjustment setting for the springs?
The pins will not wear fast, how far do they stick out of the attach plate? it should be a good inch or so to ensure it had a good grip.
C
Candyman
Less than that on both attachments.I can understand on the bucket being homemade plate but the back hoe is a factory mount.The pins aren't broken or chipped.Should there be some tension when I push the levers down to lock in?Just to mention thank you for all your insight and help.
antfarmer2
I think mine are spring loaded
I don't know the setup your has, but there should be some tension so they push out and don't get pushed back up when there is a load on them.
The bobcat machines i have use two pins that go downwards. They are round with about a 30 degree angle on the back, this pushes up against the locking tab on the bucket holding it tight. The pins are spring loaded to an extent to hold constant pressure in it so it will not be pushed back up.
C
Candyman
Your set up sounds similar to mine.Im gonna try to borrow a friends bucket and see if it stays on.That way I can just order a new plate and weld it on.Thanks for your help.Much appriciated.
C
Candyman
Tried a friends bucket on for size today and low and behold it stayed on.Looks like my mount was the problem.Thanks guys for all the help.You guys are great!!!
C
Candyman
Good to hear great job
Well picked up a new bucket and sure enough the damn thing popped off.Im at my wits end with this thing!!!When I tried my friends the one latch was hard to push down and with this new one they fell down easy.I don't know maybe I'm just not suppose to own one I guess
antfarmer2
Are they easy to pull up? Should be spring loaded
C
Candyman
Time for bailing wire or bungee coards
That's the thing that confuses me.The handles don't pop up they stay down with the pins.When I tried my friends bucket the left side was so hard to push down I hade to use my foot to get it down.But the bucket stayed on.When I tried this one the handles seemed to just fall down in the holes.Anyone wanna buy a skid steer?im so frustrated I told my wife I had to go for a long drive cause my temper sometimes gets the best of me.
antfarmer2
Mine push down a bit hard tryed ajusting them
