5625 Quick Attach Conversion
Converted from Gehl to standard QA. Now all my attachments fit. Tried for an hour to get some photos to work on here. Here they are on another forum loaded up in 10 seconds. https://www.heavyequipmentforums.com/threads/gehl-5625-new-style-quick-attach.82160/
Nice job, you have done well, I like the price of doing it too :)
I have the same skid steer without the QA.You did a wonderful job on yours. Do you have and dimensions to share, ie pipe ID/OD, steel thickness etc......?
Thanks. Still holding up. I only used flat plate, the pipes were the original Gehl quick attach that I welded to my new box. The plates were 3/8" or close to it. The thinner the box, the better. But I will say check out edge attachments, they offer a quick adapter for $800 that works well. Another guy with 5625 uses it with good results.
