Hello all! New to this site and also to the ownership of an 1835B with "issues". I am trying to remove the left drive motor per a Case service manual I purchased. Everything disconnected as instructed up to "Loosen and remove the nuts and lock washers on the Ferry head bolts that hold the motor". How do you get to the nut and lock washers inside the chain case? Looks to me like you have to need to remove the axle housings to remove the chains so the motor drive sprocket can be removed through the outboard bearing cap hole. Is this correct or am I missing something? Any info steering me in the right direction will be greatly appreciated.
