SLICK_N_STICKY
- Joined
- Aug 29, 2011
- Messages
- 21
I have a 742 with a 1.6 ford engine.Does someone know the firing order and which end is number one?
Most 4 cylinders have the firing order 1-3-4-2. However, some older Ford engines use 1-2-4-3; and from what I have read, the Kent engine (which is in you 742) is one of them. Number 1 cylinder is on the water pump end of the engine, number 4 is at the bell housing end. HTH, SR
Thanks for the info.This helps me a lot.From page 7B-8 of the service manual
Yes it is.Is 1342 the firing order for a 742B Mitsubishi
THANK YOU!Yes it is.
See attached photo.
If that page doesn't meet your serial number I do have the pages for others.THANK YOU!
If I remember correctly the1.6 in my 722 was 1, 2, 4, 3.I have a 742 with a 1.6 ford engine.Does someone know the firing order and which end is number one?
Yes the Ford 1.6 firing order is 1, 2, 4, 3.If I remember correctly the1.6 in my 722 was 1, 2, 4, 3.
