T190 Bobcat Electrical Auxillary Plug to Operate Cement Mixer
Odin123
I have a bought a cement mixer for my bobcat that did not come with the male electrical plug that plugs into the external electrical auxillary plug. The cement mixer has 4 wires feeding the relays that operate the hydraulic mixer drive and the dump gate. Has any body else wired one of these plugs up so it works with the Bobcat controls. My Bobcat dealer tells me there is no way to make this work. He says he can sell me the auxillary plug for $280.00 but doubts if I will be able to operate it using the Bobcat controls. I know this forum has vast knowledge so if anyone could give me advice as to whether it can work with Bobcat controls or if I will have to make my own auxillary switch and control it that way. Thanks.
Do you have a picture of that plug? And what machine do you have with Serial #? I can look it up how you need to wire it. Do you know anything about the Mixer?
In the past before these fancy skidsteers came out guys would just buy a couple of either rocker switches or toggle switches that are momtary and run a wire from the battery to the attachment with the switches installed, I have done it many a time.
Thanks ward. Did you have these switches in the cab of your skidsteer? I know at the top of the front of the my Bobcat where the quick Tach switches are there is room for more switches.
Fortworth-cowboy. Here are the pictures of my serial number and the auxillary plug. The picture of the blue diverted valve is what I need to actuator. The diverted valve shown is damaged but I have anew one that has 2 relays on it and each relay has 2 wires coming off them. Thanks for any information that you can provide.
Could you also take a picture of the 4 Wires? Or does the Attachment has a connector?
There is no connector on the cement mixer diverter valve. It has 2 solenoids with 2 wires each. One would send hydraulic fluid to operate the mixing screw and the other would open and close the dump gate to unload the cement from the mixer.
Fortworth-cowboy, here is a picture of the new diverter valve. Thanks.
My machine is a Bobcat T190.
There is no connector on the cement mixer diverter valve. It has 2 solenoids with 2 wires each. One would send hydraulic fluid to operate the mixing screw and the other would open and close the dump gate to unload the cement from the mixer. My Bobcat is a T190. The serial number is 531616504. There are pictures of the plug in pictures above in past replies as well as a picture of the diverter valve. Thanks for your help.
So, I think the best would be if you take Power and Negative form Pin D and 3. That Power is switched Power, so it is only on when the machine is in ACC/ On.
Otherwise you would need a Controller, because the rest is Can Wires and you can not run anything on that.
So use the Power and Negative from the connector and run 2 Wires up the Boom and connect these to 2 Rocker Switches or maybe even one.
Thanks fortworth-cowboy. Is there a diagram showing which pin on my bobcat matches exactly to the diagram you provided (I mean that corresponds the diagram you provided to the round configuration of my auxillary plug), or do I probe my connector using a test meter for the power and ground? Also, would you buy the male auxillary plug from the dealer or could individual crimp on connectors be used to plug into the power and ground wires on the female auxillary plug attached to the Bobcat?
The C426 connector should be pinned the same way as the main frame harness connector. Same Letters and so on.
At the front, by your AUX coupler, I would just test it out. I know that the bigger connectors are ground, switched power and unswitched power.
Make sure you use switched power otherwise you could drain your battery.
I can look on the weekend if I can find an old cut off from an attachment connector what I could sell you.
I know that the connector you looking for is at least $50 by the dealer plus around $30 for the pigtails.
Thanks fortworth-cowboy. I am in Saskatchewan Canada. The plug here at the dealership is about $310.00.
I could sell you this attachment cable, which is already wired up.
Here is the link from Bobcat
I would sell it to you for $100 plus shipping ~ $35
Thanks fortworth -cowboy. If I bought this cable would I be able to use any of the switches on my joystick controls to operates the Mixer and dump operations on the cement mixer or will this just give me power and ground to run to rocker switches, and if so what terminals do I use to tap into the green plug on your cable ( round pin flat , etc)? Thanks for your time and efforts.
Unfortunately you would only be able to use power and ground. These wires include CAN BUS wires and it would only work if you could find an attachment with an controller specific for Bobcat.
Thanks fortworth-cowboy. How can I buy this cable and is there a male plug available to connect to the green plug on the cable you had a picture of?
