T190 Bobcat Electrical Auxillary Plug to Operate Cement Mixer
Odin123
I have a bought a cement mixer for my bobcat that did not come with the male electrical plug that plugs into the external electrical auxillary plug. The cement mixer has 4 wires feeding the relays that operate the hydraulic mixer drive and the dump gate. Has any body else wired one of these plugs up so it works with the Bobcat controls. My Bobcat dealer tells me there is no way to make this work. He says he can sell me the auxillary plug for $280.00 but doubts if I will be able to operate it using the Bobcat controls. I know this forum has vast knowledge so if anyone could give me advice as to whether it can work with Bobcat controls or if I will have to make my own auxillary switch and control it that way. Thanks.
Do you have a picture of that plug? And what machine do you have with Serial #? I can look it up how you need to wire it. Do you know anything about the Mixer?
In the past before these fancy skidsteers came out guys would just buy a couple of either rocker switches or toggle switches that are momtary and run a wire from the battery to the attachment with the switches installed, I have done it many a time.
Thanks ward. Did you have these switches in the cab of your skidsteer? I know at the top of the front of the my Bobcat where the quick Tach switches are there is room for more switches.
Fortworth-cowboy. Here are the pictures of my serial number and the auxillary plug. The picture of the blue diverted valve is what I need to actuator. The diverted valve shown is damaged but I have anew one that has 2 relays on it and each relay has 2 wires coming off them. Thanks for any information that you can provide.
Could you also take a picture of the 4 Wires? Or does the Attachment has a connector?
There is no connector on the cement mixer diverter valve. It has 2 solenoids with 2 wires each. One would send hydraulic fluid to operate the mixing screw and the other would open and close the dump gate to unload the cement from the mixer.
Fortworth-cowboy, here is a picture of the new diverter valve. Thanks.
