bobcat t190 shutting down from low oil pressure
J
joesmith123
error code
fuse box, that wire was there when I opened it
There is one flash on the lift tilt light
haymaker
I wish someone here could offer up some suggestions Joe. I have no experience with this issue.
I am very surprised there has been no one with any ideas.
brdgbldr
I am not overly familiar with the T190.
If you press and hold the "Lights" button, do you get any codes?
It looks like the machine has had electrical problems in the past that have not been properly fixed. This will probably make it more difficult to diagnose and fix the machine.
J
joesmith123
I have been reading and going through what others have done, look at what I found, it could have been the problem
This is the solenoid that controls the BICS for lift and tilt
It looks cracked in half, and the wires under it were barely connected
It could be the solution, tomorrow part should arrive and we will find out
J
joesmith123
I was wondering how people were getting codes but all I know is to get to the screen that says "hydraulic lock valve open circuit"
I will try, "pressing and holding the lights button"
I thought the same, that the machine has had electrical problems but,
Once I read up on the fuse panel, that wire they have running is for lights of some kind
There really is not much going on in the fuse panel, mostly relays
The wiring seems overwhelming at first, but once you clean everything, you can start to understand and find the problem
J
joesmith123
I hope this is your issue. E
Same, I must've spent 10 hours yesterday, testing voltages, reading through tons of old threads from all kinds of forums, watched tons of videos on how people deal with this
From what I remember, when I put 12 volt into that circuit that the bad solenoid is on, I do remember the computer flashing twice
And flashing twice meant Circuit voltage same as battery (12 volt)
And its not supposed to be, it should be lower than 12 volt
But in those videos where people bypass the BICS using a relay, are they not putting 12 volt on that circuit?
I still do not understand how they successfully did it with adding a 12 volt source
We'll see what happens tomorrow
haymaker
My computer antivirus started mid sentence, and I could not continue.
I was saying even if you don't get many replies with some detective work you can often find someone that has had a similar issue.
It is a painstaking task reading through all the posts but much better than proceeding blindly.
The people here have a lot of great experience and knowledge to share.
Good luck! Be sure to let us know what happens.
J
joesmith123
Yes I am hopeful that I will figure it out
Before cleaning it and tracing the wires, I felt overwhelmed and doubtful, but
Once I cleaned everything and tried to understand it, it feels more hopeful that I will fix it
That solenoid barely had wires connected, and it looked swollen to the point of rupture
It could be the problem, but I'll believe it when I see it
brdgbldr
When you press and hold the "Lights" button the codes will come up where the hour meter is. When you let go of the button the codes will come on one after another. There will probably be more than one code, so be ready to write them down.
J
joesmith123
solved
I installed a new BICS solenoid to replace to swollen one pictured previously
prayed before turning machine on that it would solve it,
turned machine on, problem was solved
ThomasWisconsin
I would contact the owner, as ot is their machine and mostbus us skid guys know our equipment and issues. This will relieve your stress level and maintain a good friend.
