Mine has some sort of garage organizer hook from HomeDepot screwed into the roof of the cab. It's horrible and hack, and doesn't even work well.I get it, but I like fixing things bungee strap would bug me.
hopefull you can fix thatMine has some sort of garage organizer hook from HomeDepot screwed into the roof of the cab. It's horrible and hack, and doesn't even work well.
Thanks John, I have some springs on order. Hopefully it takes care of the issue. I will report back when they arrive as to how it goes.Malcolm,
The lap bar is held up mechanically. Hopefully you can locate the parts needed.
In my case, all I needed were the springs and the rest I built back up with my welder.
The current springs are built heavier and quite an upgrade from the original ones. They were not too expensive either but, of course, it has been several years ago that I fixed mine.
John
Its what I usebungee cord works on mine lol
There is a spring loaded curved steel plate at the lower end of lap bar on either side to hold the bar up. Tighten the bolt on spring so the plate creates enough friction to hold bar up. These plates can get warn thin and need to be replaced so you can put enough force on bar.Mine has some sort of garage organizer hook from HomeDepot screwed into the roof of the cab. It's horrible and hack, and doesn't even work well.
My plates and the bar itself are badly worn. I'll have to build the bar back up with the welder. It looks like the plates aren't too expensive.There is a spring loaded curved steel plate at the lower end of lap bar on either side to hold the bar up. Tighten the bolt on spring so the plate creates enough friction to hold bar up. These plates can get warn thin and need to be replaced so you can put enough force on bar.
That should do the trick.My plates and the bar itself are badly worn. I'll have to build the bar back up with the welder. It looks like the plates aren't too expensive.
well which bolt should be tightenable the inside one or the outside one? both seem to be super tight already I can put a cheater bar on my 14 mm wrench but feels like it's just going to strip the bolt headIt looks like the plate is thick enough. Did you tighten the bolt on spring and see if the bar stays up?
just wondering if you got the springs and if they helpedThanks John, I have some springs on order. Hopefully it takes care of the issue. I will report back when they arrive as to how it goes.
Malcolm
Yes they came in. I haven't had a chance to install them yet. Fixing a whole host of issues on it. As soon as I do I'll report back with pics and an update.just wondering if you got the springs and if they helped
