S185 and Bobtach Part ID/help finding
logan1211
Hey everyone,
Recently did pins and bushings on my S185. I accidentally damaged the threads on the little plate where the grease zerk goes on the backside of the tapered pin on the lower Bobtach attachment. I went to touch those threads up and broke my tap off... cheap metal. Lesson learned.
Anyway, I can't get this dang broken bit out. Super hard and apparently very brittle, struggling to weld to it or get a drill bit in for easy out.Was just going to order new... problem is, I can't find this part anywhere. Anyone know what'd I should be searching for or can recommend here?
This is the small plate/disc held in by the snap ring on the inside of the tapered pin. (Pic attached)
Thanks in advance!
Making progress.... just a steel plug. Found one that says not compatible with my model. Wish it had measurements.
Bobcat part for the incompatible is 7170613.
And we're done here... for anyone in the future. Finally found it
