The engine in the Bobcat 610 I just got is running rough. The #2 cylinder seems to be the source. When I remove the plug wire to that cylinder it seems to run smoothly... That plug was wet but otherwise looked new. That cylinder and two others have a compression of 90lbs. The #4 was about 85lbs. Distributor cap looks new. Plug wires are old but but I swapped wires and the problem remained with the cylinder and did not follow the wire. I swapped the plugs and problem remained and did not follow the plug. Ideas? What am I missing? Thanks
