Wiring harness to add windshield wiper
mfyock
I just picked up a factory New Holland cab door. The door has the factory wiper on it. Do the skidsteers have a harness on them already to plug the wiper into? It sure seems like the machine would have a universal wiring harness for all the skidsteers, then you would plug the wiper into it it if you buy that option. Would the connector be up by one of the lights? Thanks!
[FONT=Swiss721SWA,Bold]
It takes a separate harness. I think this might be the part number for the harness. Also, here is the instructions for the wiring.
WIPER/WASHER WIRE HARNESS
INSTALLATION
[/FONT]
1. Disconnect the battery (-) negative ground
cable, if not previously removed.
2. Remove the cab side panel to access the
service/run switch and fuse panel area by
removing two bolts, 1. Open fuse block
cover, 1, Figure 14.
3. Route the 26​
long end of the main power
wire harness, reference 9, Figure 4, with the
O/GY (orange/gray) connector and the B
(black) flat hole-type connector through the
cab at 2, to the fuse block area. Allow the
remaining 44​
section of the harness to hang
in the right front corner of the cab at 3.
4. Locate the single (O/GY) wire connector
from the wiper 7.5 amp fuse and connect it to
main power harness as shown at 1. Attach
the black (B) ground wire on ground stud, 2.​
[FONT=Swiss721SWA,Bold][FONT=Swiss721SWA,Bold]
NOTE: When attaching ground wires,
always place the heaviest ground wire
next to the ground surface. Stack the
remaining ground wires according to
wire size or number of wires with the
single spade connector with the largest
first and the smallest on top.​
[/FONT]
[/FONT]
Reinstall the cab side panel previously​
removed.
INSTALLATION
3. Route the 26
″ long end of the main power
remaining 44
″ section of the harness to hang
removed.
Part number 86552688. Is there a way to edit posts?
