i like to check axle bearings. you can get a good idea of how they are by raising the machine off the ground a little and checking end play at the wheel. if you can find any kind of servic history that would be good too. make sure to consider lift capacity, lift height and reach.Check the engine is cold, this is a good indication of tompression and wear. Starting a warm engine tells you very little. Check the smoke, if it pours it out, you have low compression or blocked injectors.
Check pivot points for slop when operating the hydraulics. Move up to an object that is unmoveable like a large tree. Push and see if you can get all four wheels to spin. This is a good way to test the drive power. All skid steers shoudl be able to do this on dirt. On sticky surfaces like bitumen, it probably won't do it.
It always helps to let it warm up fully and run the machine. Check the boom for cracks you might have to look close especially at the lift and tilt pin bosses. Don't forget to get in and drive it dig with it lift with it. And remember to bring some one with you, because it is easy to get caught up in the moment. If in doubt get some one qualified to check it out. Rich M-37i like to check axle bearings. you can get a good idea of how they are by raising the machine off the ground a little and checking end play at the wheel. if you can find any kind of servic history that would be good too. make sure to consider lift capacity, lift height and reach.
Generally speaking, you will get about 6,000 hours out of a diesel engine. The hydraulics and hydrostats should do more than that if kept clean and maintained.What about hours run? What's to high?
Most of my customers trade in there skidsteers at 3000hrs, after that to unreliable for full time work.But customers that only use them on small farms 4000hrs to 10000hrs but they spend a bit keeping them running . Not uncommon to see them buy a skidsteer for $4000 and spend $5000 to $10000 on repairs in the first 12 months. Try to buy with the lowest Hrs you can afford.Generally speaking, you will get about 6,000 hours out of a diesel engine. The hydraulics and hydrostats should do more than that if kept clean and maintained.
Some die faster, some will last longer. A cold start is a good test for engine condition.
