RobPg1967
- Joined
- Oct 10, 2005
- Messages
- 46
Ive got my 743b set up with the 8ft. fisher plow and its worked flawless all winter - until now. 1. After plowing for 9 hrs - I was pushing back some piles of snow and when under a slight strain - the engine would die out - unless I stopped all movement then it would idle back up to high. One time , when I wasnt even moving , it idled all the way down to a stall - but then started right up again. I parked the loader since I was done with my work. My first guess is water in the fuel - the temperature was very very cold prior to plowing that day and then the temp went way up above freezing at the time of these symptoms. I added some diesel additive and filled the tank - when I start it tomorrow maybe that will do the trick. 2. The front door on this loader has a factory wiper setup. The wiper arm somehow popped off the grooved post and for the life of me I cant figured out how the arm stays on. I tried sliding the wiper arm (which has female grooves)back onto the post (male grooves ) but there are no clips or anything to keep it from slipping off- did I lose some parts ?? Hey any help and/or suggestions is always appreciated - you guys really know your Bobcats.
