Volts on a s200 bobcat
( I have a code 34-04 no power to the panel)and was thinking it could be my battery it’s like 5 years old but I have 12 volts with the bobcat off
if you in doubt about the condition of the battery because of age put it in another machine and see if it cranks ok , if you do not have a battery load tester that is. check your manual for fuse and relay locations and check cable ends at battery and grounding to machine.
Thank you never thought of a load tester !!
With the ignition off how many volt’s should my s220 bobcat have ?
A healthy fully charged batter should be 12.9 to 13.1 volts at rest.
75% is 12.6-12.9. 50% is 12.4-12.6. 25 % battery is 12.2-12.4.
12 volts on a 12V battery is way low.
