trencher
bmh
I have to hold the switch on my 773 hand control to run my trencher so it will dig (turn) the right way. Any way to not hold the switch. also can i speed up the flow of hydraluic oil to turn faster?
How about if you switch the couplers on the trencher around, would that reverse the flow?
If you press the "aux hydraulic" button twice and pull the trigger it should stay running with out having to hold the switch. If the chain and auger is turning backwards when you hit the button twice and pull the trigger you may have to switch the couplers on the trencher.
