Track 650 display fuel to hot???
Mountain West
Display is reading fuel to hot. It will bog down and run as if filters are clogged then takes off running like nothing happened..Any help will do. Thanks in advance.
seen this . of course check fuel cooler. but issue is probally bypass valve located in tee at fuel lines by filter. if i rember corecctly tes is pinch off bypass hose forcining fuel thru cooler
