Tl-130 oil change
You've probably already figured out, but underneath there is a little door you unbolt, but I believe you have to have a special tool that hooks onto the drain plug that has a 90 degree elbow to drain through the little door. I don't have the tool and just remove the bigger part of belly pan and drain into pan.
