T770 Glow Plug location
mauidude
I have a 2013 Bobcat T770 with a Bobcat (Doosan) engine. Where are the glow plugs located? I need to purge my cylinders of oil due to a rollover. Engine will turn over but wont' start. It acts like it is trying to start but my guess is due to the oil in the cylinders it can't get enough compression to fire up. Per someone's suggestion I was going to remove the glow plugs and let the engine turn over to purge the oil in the cylinders.
maybe that engine does not use glow plugs( I do not know) but the same result would be to remove the injectors. Maybe someone else will chime in that has more knowledge of that engine.
The glow plug relay is a metal solenoid above the battery inside the rear door.
If it turns over, you either have already bent con rods or there is no oil in the cylinders.
If you have any oil in there, you will get more compression not less.
Are you getting smoke while the engine is cranking?
