t750 with code h 4013
Krazy kenn
bobcat t750 has code h4013 and alarm beeps 3 times code advise says rt joy stick no connection but it performs all commands how do i reset code and see if it comes back and any other advise
The code is self clearing if not active. The issue is usually in the handle itself. Behind the seat you will find where the joysticks plug into the main harness, swap plugs and see if code changes to left joystick. If it stays right then probably a wiring issue from harness behind seat to the joystick. The code is more specifically related to the aux switches in the handle.
