First Thread, Need help with T590
Ironhorse
Hi everyone, I am new here. Been digging though posts and threads trying to resolve an issue I have. Just purchased a 2015 T590 with 5500 hrs. Very clean machine considering hrs and has a new undercarriage. Was running well for the first few times out with it in the yard. Started right up plugged in at -20C here no problem.
Last week I went to start it and it was stone dead. Replaced battery and it powered up and cranked over and sounded like it was going to fire up but just kind of half fired and cranked faster. But never caught and ran. Did a ton of searching and tested several things. I actually have the doosan program and a Uvim but thats not helping me either.
No codes unless I crank long enough to drop battery voltage.
Cranking speed is 500-600 rpms
Rail pressure is around 5000 psi which to me should be good, it is lots for most other engine brands I work on.
IMV works fine. I seem to have lots of fuel. No air in system. I put some clear line on.
Injector leak off lines dont have excessive fuel coming out.
No real smoke coming out of exhaust, I removed DOC to check right at turbo.
If I unplug rail pressure sensor while cranking it will smoke black and kind of fire more but then cuts off injectors and codes out for rail pressure sensor.
I am stumped here. Any one have insights, Did something go wrong with the battery being dead? Unit ran awesome before. Previous owner has not had these issues.
I don’t have this machine but I run a t550 elsewhere. So you have fuel, glow, air…I would check cyl compression for peace of mind. Doubt that a dead battery would cause a major mech issue, but could be a coincidence.
Also what firefighter said…
Ok, Update. It runs again. Ended up being a rail pressure sensor. I went through every system on that machine. Cleaned wiring up. Checked voltages. Went through fuel systems. Was down to something like a ecm reading something wrong or a sensor. The unplugging rail pressure sensor and it smoking black lead me to try a sensor first. Ordered one off of Amazon and installed. Fired right up. The youtube videos from howididit were super helpful in going through all the systems for those dealing with this issue. Thanks for the help.
Thank you for posting the fix and congrats on the repair….i hate potentially having to use bobcat dealer service $$$$$. Too many posts never document the final result…
I know you resolved it but I had a Similiar problem with my t590. If any controls ie. pedals or joysticks are engaged it will do a Similiar thing. Just keep turning over.
It ended up being the auto bobtach switch being sticky and was engaged.
Can you go into more detail please. I have 2 identical machines and have swapped ecm,fuel pressure sensor, the left panel up top, I put a new air filter and fuel filter and have 0 codes until battery volts drop out. I was using it and the lift arms started acting funny would go up and not come down. Cut it off and that's the last time it ran.
