T750 Crankshaft position sensor error E000636-02
Mack2859
I have a 2014 T750 high flow. I have been getting the error E000636-02, Crankshaft position sensor error, for a while now. It has gone back to the dealer several times for repair and the error persists. The following have been replaced:
Wiring harness
Starter
Primer fuel pump
All filters
The unit runs for a while and then it throws the error. RPMs drop making it unusable. What I find interesting is that the error doesn't get stored in the history.
This is a Tier 4 Kubota engine. I am at a loss on what to do next. Despite the dealers efforts, it still does it.
Any help would be appreciated.
Mac
ATF613351
Which harness was replaced? Because there are 2, one from the ECU to the ECU Harness and then the Ecu/Engine Harness.
If you look on the PDF I attached, it is either Part #11 or #41. Which harness was replaced?
  • Engine Electrical Circuitry (Engine Sensors, Battery, ALT & Starter)_T750.pdf
