T650 Error Code
KS2335
Looking for infor on Error code E000731-21, the info that I have found shows it to be a Fault on the Accelerometer 1 Sensor Decode Circuit. Any help what to do would be great.
The accelerometer is the knock sensors on the back (door side) of the engine block. Over torqued sensors can cause this code. Loosen sensors and re-torque to 16 ft-lbs. Also check the connections to both knock sensors. it is possible one of the sensors could be bad but very rare.
