T190 wiring schematic
wct1967
T190. Set # 531617911 The engine will not turn over with key switch. I have to remove the shut off solenoid and jump starter with screw driver. Engine runs and all functions work. Has new battery. Basically there is no power going to starter or shutoff solenoid. Checked fuses, good. Does anyone have a service manual or wiring schematic for this machine. Need to figure out what is not getting power
I have a set of manuals for a T180. Email is rmghorm at gmail dot com. :-) ---Bobbie-G
I have the same problem, what did you do to sort it out?
I have a T190 with a deluxe pad. I can’t get the screen to come on. It beeps like it’s going to turn on but then it goes blank. Is anyone going through this problem and if so how did you fix?
