T190 help
OK no lift or tilt. active 32-34 code. swap connectors does code change?(easy breezy)
Hi All, good news, the T190 ACS system seems to be back on track and working fine. I was ready to give up and hall it off to Bobcat, but I had a nagging feeling that I wanted to give it one more try. We got it, and if anyone is having issues with actuators, I learned a few things on this one that might just save someone else some headache and expense.
As for my long posts...Sorry, 7lbssmallie, I can be a little long winded when trying to work out tough problems, but it did help to write out some of the sequence of errors to realise how the system works and what the controller is looking for. That, and from every post, I got some very useful suggestions that helped point me in the right direction.
That said, a big Thanks to BC743G, honestly, I am not sure I would have figured it out had we not had an ongoing dialog and had I not followed most of your suggestions. It is possible what I "figured out" you already knew and where trying to point me there, so sorry if I missed the obvious.
At this point, I can say that is has been both frustrating and very rewarding. I went into my project wanting to so something simple and it turned into a crash course on bobcat ACS operating systems.
Thanks again for everyones help and interest. And BC873G, I would be happy to touch base by private email, not sure the best way to share that. What do you suggest?
Hey, that is good news.
I shared an email address with my profile (BC873G). You can get the email from the member list or probably by clicking on my user name on one of the post. Would be great to hear a bit more of the detail through email. Let me now if you don't find it.
I'm having the same problem, 32-34 code. What finally solved the problem?
all good bro. quick read, problem solved, now . symptons of initial problem. how we came to our conclusions. what we did to fix it.. clear concise and on point. do this . type stuff. should be youre next post. separate the chaff. yea it kinda sucked getting there. but you got it done. GOOD FOR YOU.. this stuff aint easy, and its not only time its out of pocketbook.
I'm having the same problem. What did you finally do to solve the problem?
If you read through the posts, he tells what was done.
