T-bar controls
randy4354
Has anyone here done tracking adjustments on the t-bar? My left hand t-bar does the forward, reverse and turning. I had to have the right servo control shaft repaired(welded). After replacing the 2 adjustment nuts back as close to where they were(I made a tube spacer that would slid over the shaft to give me the depth to place the first nut, then install the lock nut. Well now the tracking is to easy to turn to the left and I have compensate a lot to pick it tracking straight. I talked to the local dealer and the mech said you need to get to a new starting point with the linkages. I found his process confusing so they suggest bring it in. Surprise, surprise! Any help with this would be wonderful! Thx Randy
